October 4, 2018 at 2:56 pm
aCVP
SubscriberHi all. I cannot get ANSYS Discovery Live to recognize all of my inlets as inlets. I have attached an example of when it automatically recognizes an inlet vs. when it does not. Any help would be appreciated - thanks!
October 4, 2018 at 2:57 pm
October 5, 2018 at 4:37 am
Naresh Patre
Ansys EmployeeHello aginn,
After selecting first inlet face, press "Ctrl" key on your keyboard to select additional inlet faces.
Naresh Patre
October 5, 2018 at 9:00 pm
aCVP
SubscriberI have tried this and unfortunately it is still not recognizing the inlet. Do you think it is a geometry problem?
October 7, 2018 at 10:03 pm
aCVP
SubscriberWould it help if I posted the geometry?
October 8, 2018 at 7:13 am
Naresh Patre
Ansys EmployeeHello,
Unfortunately, I cannot look into the geometry files. Other student community users can help you by looking into the geometry if you post it.
BTW, how many inlets and outlets are there in the model?
October 8, 2018 at 12:49 pm
aCVP
SubscriberThere are four small inlets and one outlet.
Thanks!
October 8, 2018 at 1:34 pm
FrankD
Ansys EmployeeAginn
It looks like the good one is both planar and also has a planar neighboring face that can nicely be filled to create the inlet face.
Try using the Fill tool on the geometry (first, and alone) to make some filled-face geometry that represents the inlet face. In doing that, you should see the problems that the neighboring geometry is introducing. Remember that Fill is only as good as the surrounding faces to the fill, since what is happening (basically) is that those faces are being all extended until they meet (or diverge, and then you have your case.) Now, knowing that you can start to ease the problem by breaking up the loop, creating helper (curve) geometry, and/or creating surfaces manually.
Perhaps the second problematic face is Close to Planar (it is really hard to tell from the picture) and you might use the Simplify tool on it?
You can always post even a small portion of your geometry if you need specific ideas.
F
October 10, 2018 at 1:36 pm
aCVP
SubscriberThis really helped - I was able to get it to work. The problem was in the neighboring faces.
Thank you for the help - I appreciate it!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
