July 12, 2022 at 11:55 am
n.koetsier
SubscriberGoodafternoon,
At our company (MechDes) we are looking into Ansys Discovery. During trial periode we found that the modeller works slower compared to spaceclaim. Rotating, panning, pulling, moving, all commands are more 'sluggish' compared to spaceclaim.
It is also visiblie in the task manager. Spaceclaim utilizes 100% 3d gpu graphics. While Discovery utilizes around 60%. Settings are the same.Is this a known issue? Is there any fix possible to have the same performance as in spaceclaim?
Thanks in advance.
Greetings,
Nick Koetsier
July 12, 2022 at 1:11 pm
Devendra Badgujar
Ansys EmployeeHello Nick Koetsier
We have not seen this before. Are you experiencing this behavior with any specific model or is it happening in general?
Please try updating your graphics drivers directly from the manufacturer website (i.e. NVIDIA).
You might also want to clear your user settings from File > Settings> Advanced > Reset All User Settings.
Regards. -
July 12, 2022 at 1:15 pm
n.koetsier
SubscriberHello Devendra,
No, it is with every model. And my drivers are up to date. We have this on 3 different pc's. And also our software provider Infinite has the same problem.
July 12, 2022 at 2:58 pm
Devendra Badgujar
Ansys EmployeeNick Koetsier
Which version of Discovery are you using?
When running under Discovery Modeling at least 2 GB of discrete video memory is required (4+ GB recommended).
Make sure your computer is using the main graphics card for Discovery. Sometimes especially with laptops, Windows might assign a low performance graphics setting to Discovery.
Regards.
July 12, 2022 at 3:06 pm
n.koetsier
SubscriberDevendra Badgujar
I am now running 2022 R2. I have a 4gb card (quadro M4000M)
I think it is using the quadro card, becaus in task manager I can see the 3D percentage go up to 40%.
Is there a way to confirm this?
July 12, 2022 at 3:28 pm
n.koetsier
I have done the above:
- confirmed driver up to date
- graphics settings of discovery is set to performance
Still no luck.
July 13, 2022 at 8:28 am
Devendra Badgujar
You can try a couple of things with Discovery and SpaceClaim to improve graphics performance:
1. Turn off Enhanced view of geometry
2. Turn off anti-aliasing and recalculate RetenderingRegards.
July 13, 2022 at 8:43 am
n.koetsier
SubscriberHello Devendra Badgujar
Thanks for the reply. Unfortunately still no effect. GPU maxes out at 40/50% usage.
Also not a cpu bottleneck. Would you maybe have time to call over teams about the problem?
Thanks in advance
July 13, 2022 at 9:32 am
Devendra Badgujar
Please can you try disabling Intel graphics on the machine and see if that helps.
Can you try reinstalling the application again with Administrator rights? Temporarily turn off firewalls and antivirus during this.
I'm not sure if GPU usage is the correct measure for performance in modeling, will have to discuss this with the team and get back to you.
Regards.
July 13, 2022 at 9:47 am
n.koetsier
I will try what you said.
It is not only visible in task manager. But I can also see the difference in response time and frame rate in discovery vs spaceclame. 2 programs next to eachother.
Thank you
July 18, 2022 at 11:31 am
n.koetsier
SubscriberDevendra Badgujar Hello Devendra,
I still have the same problem. I am thinking it is in the Ansys software or maybe some other driver? -
July 18, 2022 at 12:28 pm
Devendra Badgujar
Discovery doesn't use all the available GPU and consumes memory which is only required for that geometry involved. It won't use 100% GPU as it might cause a crash.
Please can you share a short video describing the behavior in both Discovery Model mode and SpaceClaim?
Regards.
July 18, 2022 at 12:29 pm
n.koetsier
SubscriberDevendra Badgujar Where kan I send this video to?
July 18, 2022 at 12:37 pm
Devendra Badgujar
Please send the video to ansys-discovery-support@ansys.com
July 18, 2022 at 1:30 pm
Devendra Badgujar
Please try installing the latest redistributable. You can try installing the appropriate one from here: Latest supported Visual C++ Redistributable downloads | Microsoft Docs
Please try installing the VC_redist.x64.exe and vc_redist.x86.exe for Visual Studio 2015, 2017, 2019 and 2022 package. If you already have 2015 installed, you may need to uninstall before installing this downloaded version.
Let me know if this helps.
Regards.
July 19, 2022 at 1:21 pm
n.koetsier
SubscriberDevendra Badgujar Also I have tried this, but without luck.
I have sent you 2 videos of the same model. You can see the difference between discovery and spaceclaim. It is small, but for me very noticable during modelling. -
July 19, 2022 at 1:28 pm
Devendra Badgujar
Thanks, will check and update you.
Regards.
July 20, 2022 at 10:04 am
Devendra Badgujar
In the Discovery video you shared it has a simulation setup which means it's not a 1-1 comparison to SpaceClaim. You can try this model without simulation setup in Discovery and check.
At least 4 GB of discrete video memory (8 GB recommended) for Explore stage, and when running under Discovery Modeling at least 2 GB of discrete video memory is required (4+ GB recommended).
Regards.
July 20, 2022 at 12:24 pm
n.koetsier
SubscriberDevendra Badgujar Also without the simulation it is slower.
Also our provider, Infinite, has the same problem on their hardware. They also contacted Ansys; And got the reply that it is just the software, just the way it is. Ansys doesn't see it as a problem... Unfortunately. Hopefully fix in future versions.
July 20, 2022 at 1:00 pm
Devendra Badgujar
Thanks for your update. We will take a note of the suggestions.
Regards.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3694
2564
1765
1234
592
