Discovery Import
Discovery Import
ANSYS Discovery parameter sweep: Boundary conditions and result export
    • eero.immonen
      This tutorial shows how to create geometry parameters in ANSYS Discovery: https://discoveryforum.ansys.com/t/35hxjav/discovery-explore-mode-performing-parameter-sweep-study
      However, I'd like to have inlet flow velocity as a design parameter, and I'd like to export the design exploration results to one or more files for further processing.
      Is this possible and, if so, how to proceed?
    • Naresh Patre
      Hello EeroI
      As of now, only geometry parameters can be used in parameter sweep. Also, the design exploration results cannot be exported. Last month, we had just the 2nd release version of Discovery and I expect these features to be available in a couple of next releases (by next year).
    • eero.immonen
      Thanks for the quick reply. Would there be any temporary workaround, e.g. by using script parameters?
    • Naresh Patre
      Hello EeroI
      Even script parameters are not exposed. The best workaround for now would be to continue using Discovery Live.
Viewing 3 reply threads
