May 11, 2021 at 6:17 am
niki1104
SubscriberHi,
I have been trying to load a model onto the discovery system. But even though it shows that the model has been uploaded, there is no visual of the model available. Please refer to the image attached which further explains the problem that I am facing. I did insert a discovery model called duct assembly but even though the model loads, I cannot see the model. Any help would be appreciated! For reference, I am using discovery student and my laptop's configuration matches the requirement to run the software.
May 11, 2021 at 6:23 am
Charudatta Bandgar
SubscriberHello Nikhila Kalia
Please refer to this query to solve this issue. Although since you are working with a student license, I will suggest you post it in ANSYS Student Community to get further assistance.
Regards.
May 11, 2021 at 6:59 am
niki1104
SubscriberCharudatta Bandgar Ah thank you so much for a promt reply! I will post it in the student community later if further help is required. I will try resolving the issue using the method you tagged. Thank you again!
3862
2629
1859
1252
600
