December 3, 2020 at 9:21 am
flodo
SubscriberHello everyone,
I have the issue that Ansys does not take decimal numbers in the Friction coefficent for frictioncal contact (see attached picture). I both tried '.' and ',' but Ansys always wants to change it to an integer.
December 3, 2020 at 1:02 pmKeyur Kanade
Ansys EmployeeWhat value you are trying? Usually it is betwen 0 to 1. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynDecember 3, 2020 at 1:04 pmpeteroznewman
SubscribernHe was trying to type 0.46 nDecember 3, 2020 at 2:53 pmGovindan Nagappan
Ansys EmployeeArray nAre you using any ACT extensions. Check and see if this popup is generated by ACT extension. From project page, go to Extensions -> View log file to see if there are any errors printednTry this and see if it helps:nCLose all Ansys and WB applicationsnOpen a directory/folder and type this address %appdata%\Ansys\ and press enternRename the folder V192 to V192_old and start WB againnWB should start with default settings. See if this resolves the issue. Any ACT extensions will have to be reinstalled after thisnDecember 3, 2020 at 5:43 pmflodo
SubscribernThank you for you comment and help. I tried do it like you described in your message but unfortunately it didn't solve the problem.nHere is a picture of the Log File:nAnd the new Folder structure:n
It still shows the same error message if I want to typ in an decimal number. Do you have any other idea of how to resolve this issue?.
Viewing 4 reply threads- The topic ‘Ansys does not take decimal numbers’ is closed to new replies.
Trending discussions- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Fluent Meshing Batch Mode – Problems workflow commands
- Local mesh refinement with targeted edge lengths at specified areas
- Mesh Element Quality Display Style Not Showing
8808
4658
3153
1680
1470
