September 5, 2018 at 6:06 pm
jason.mitchell
SubscriberI am running ANSYS 17.2 and just installed ANSYS Electromagnetics Suite.
When I try to run it says license server cannot be found.
Do I need to update my ANSYS license server
September 5, 2018 at 8:46 pm
Peter Serano
Ansys EmployeeHi Jason,
You need to have at least the same version or greater of the ANSYS license server installed. If your University/Lab only has the ANSYS 17.2 license server installed you'll need to contact your IT support staff to update it or install v17.2 or lower of the EM Suite / Electronics Desktop on your PC.
Best,
September 5, 2018 at 9:20 pm
jason.mitchell
SubscriberPeter,
Thanks for the reply. We just updated the license server and are still having the same problem.
Best,
Jason
September 6, 2018 at 11:06 pm
Peter Serano
Ansys EmployeeThere are a few things that could blocking access to the license server:
1) Windows Firewall: You can temporarily disable the Windows Firewall to see if it's the issue. If it works when the firewall is disabled you'll need to 'allow' the ANSYS programs to access the internet - or manually open ports 110, 1055, and 2325 on your local machine.
2) Anti-Virus / Anti Malware: Additional security software can also block the ports the license server communicates on - like the firewall, you can temporarily disable it to see if it fixes the problem - if if does, make sure the ANSYS programs are listed as allowable exceptions.
3) Host name resolution: If your license server is specified as a host name, try re-running the installation and use the direct IP address to specify the license server PC instead of the host name
4) Issues 1 & 2 can also effect the license server so repeat those steps on that PC as well to make sure the proper ports are open and accessible on your LAN.
September 7, 2018 at 1:34 pm
jason.mitchell
SubscriberI am able to access the license server with Workbench 19.2 so I don't think that is the issue.
September 7, 2018 at 3:44 pm
Peter Serano
Ansys EmployeeDid you attempt to disable the firewall and/or anti-malware on your local machine temporarily to see if it fixed the issue? - When you install a new version of any ANSYS software it *should* automatically add a Windows Firewall exception for the new executables that are part of the EM suite but it may not... This is why I recommend manually setting incoming and outgoing rules in the Windows firewall to open TCP/UDP ports 110, 1055, and 2325 on your local machine.
Also to make sure I understand you correctly, you say you are running Workbench v19.2 and EM Suite v17.2?
- Workbench error
- Workbench not opening
- License Error
2524
2066
1279
1096
457
