3D Design
3D Design
ansys electronic desktop 2022 r2. icepak.
    • narges gh
      hi.what is a diffrenet between glycol 20- 35-80,... which one shall use in turbular for cooling.
      and turbular which temprature shall put for inlet and outlet. and how can we have closed system and open system
    • Nikhil Tamhankar
      The different numbers with the glycol are just the % concentration level by volume/mass.  If the Air Region has an Opening boundary condition, then it can interact with the surroundings with the velocity inlet / pressure outlet opening condition, otherwise its a closed system without an opening. Similary for liquid cooling systems, the block having the liquid material must have an opening boundary conditon on it connecting it to the extents of the Air Region box for it to be an open system.  You can assign the incoming fluid temperature using an Opening Thermal BC on the fluid block to specify its inlet temperature and then the outlet temperature is computed using the flow and energy equations.
