November 7, 2018 at 3:51 pm
jpervez
SubscriberA new installation of your Ansys product has been detected. The library directories have been reset to those of the newly installed libraries. To change this go to Tools/Options/General Options. I get the above message when I try to to fireup "anssysedt" from Linux terminal
November 7, 2018 at 4:19 pm
ANSYS_MMadore
Ansys EmployeeThat is not an error, that is the normal popup for a first time run of Electronics Desktop.
What is the full output from the Linux terminal?
Thank you,
Matt -
November 7, 2018 at 4:29 pm
jpervez
This what happen when I try to opem ANSYS electronic desktop.
1. I run the command “ ./ansysedt” from linux command line
2. Ansys Electromagnatic desktop opens up. It goes away and a small popup window opens and it says the message “ A new desktop window ……..”
I click ok. Then window goes away and I am in the command prompt. It seems to be looking for more command. Then I ctrl+C on the terminal to get the shell porompt.
Desktop GUI never opens
November 7, 2018 at 4:35 pm
ANSYS_MMadore
Ansys EmployeeHow long are you waiting before you kill it with ctrl+C? Depending on the environment, it may take a few minutes for the GUI to appear.
What is the version of Linux on the machine?
Are you physically at the Linux machine or running through a remote display? If through a remote display, please ensure it meets the requirements as outlined in this posted document. https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/remote-display-virtual-desktop-support-192.pdf?la=en-in
Thank you,
Matt
November 7, 2018 at 7:43 pm
jpervez
SubscriberOK. This time I installed it a desktop where I had full access to the desktop X11 and I was able to see the GUI. It did not show up when I "ssh -X" to my desktop. Thanks for the help. May be it was my X11 environment. I can further troubleshoot from here.
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1349
1118
461
