December 21, 2022 at 6:21 pm
zlEM
SubscriberMostly using HFSS designs. Although the simulation results have been generated and saved, when reopen the project, the project cannot read the results, i.e., it is empty under Results -> Solution Data, and the 'Browse Solutions' and 'Clean Up Solutions' buttons are grayed out.
The .aedtresults folder remains the same size as when the results can still be read. Wonder what could be the reason to cause such a problem and if there is a way to solve this.
January 4, 2023 at 1:33 pm
Praneeth
Ansys EmployeeHi user,
Thank you for reaching out to us and we appreciate your patience.
Please provide more information to help us serve you better as this is a very unique case and to narrow down the root cause. Some initial queries based on your post are -
- Do you observe this for every simulation model that you are working?
- Since when did you observe this?
- Did you try to do any model editing after the solution is generated?
- Did you do any action on the folder containing the results after the simulation is complete?
Best regards,
Praneeth.
- Workbench error
- Workbench not opening
- License Error
2524
2066
1279
1096
459
