Ansys Electronics Desktop- stuck at Analyze All step
    • jyosrimanaswitha
      I created Patch Antenna design with layers in-between the substrate and the top layer of the Patch Antenna.
      the system is stuck at "Building Matrix" step at Analyzing. There is no output or moving to next step in my system. While the same file is running on other system.
      Please let me know how to check where the problem is.
    • Praneeth
      HiArray,nPlease use upload image to share screenshots for your issue as Ansys employees we cannot access the attachments across the forum.nIf it helps try restarting the application and system and check again.nAll the best.nBest Regards,n
    • jyosrimanaswitha
      Hi,nThanks for the reply. I will try to shut down and restart. Please let me know if you can see the below screenshot.nn
