March 14, 2021 at 7:24 pm
sugarl14
SubscriberHi there,nI saw somewhere else on this forum where someone was running into a similar issue that I am running into. Here is the error I'm getting:nnError: Cell_Function_Values: No post-processing value exists.nError Object: #fnnError: Error writing | gzip -2cf > FFF.2-1-00000.dat.gz.nError Object: #fnnIn the forum post that I mentioned previously, the moderators suggested double checking to make sure there is enough storage on the machine being used, and also that everything being saved is in English. In my case, these are all OK. So I think my issue is elsewhere.nnThank you!n -
March 14, 2021 at 10:08 pm
YasserSelima
Subscriberthis problem can happen when you are saving calculation data and then you change some model , so the data you are saving becomes unavailable n -
March 15, 2021 at 1:08 pm
sugarl14
SubscriberThank you for your response.nSo would I need to re-create my Fluent model?.thanks!n -
March 15, 2021 at 5:28 pm
YasserSelima
SubscriberNo, you need to revise the data you are saving during calculations. Monitors and data samplingn -
March 15, 2021 at 7:04 pm
sugarl14
SubscriberThank you for your response. I'll try that out!n
2726
2148
1359
1150
462
