April 13, 2022 at 5:03 am
ecore
SubscriberHi guys, I am trying to run my first custom shaped charge simulation. I am using the eulerian reference frame for the HMX explosive and Aluminium liner. Since I only have student license, the mesh element and node is limited to 128000.
After meshing the model, the mesh totals up to this:
April 13, 2022 at 6:19 pmChris Quan
Ansys EmployeeBy default , the total Euler cells is 250,000. You can find this in Euler Domain Controls under Analysis Settings. See attached picture below.
If your license has the limit on total number of elements, you need to reduce the number of Total Cells so it won't exceed the limit.
Furthermore, the total number of elements & nodes in Statistics under Mesh is for Lagrange mesh that are used to fill the Euler domain. If all bodies in the model use Eulerian frame, this mesh is not used in the analysis. So it has nothing to do with the nodes & elements limit of the license.
April 14, 2022 at 4:37 amecore
SubscriberI see. Thank you for the help.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2630
2104
1327
1110
461
