Ansys Explict Dynamics Crashing
    • rodmarti
      Hello Guys,
      I am using Ansys 2019 R2 and most of the times when I use Explicit Dynamics, te Mechanical keeps crashing.
      When I try to open the model afterwards, I face the following error message:
      Any thought?
    • Missy Ji
      Does this happen in other machines, or just a specific machine?
      If this happens to every model, then reset %appdata% might help.  Let's try forcing workbench to create a fresh set of default configurations files the next time it starts again.
      close all Workbench window
      Start > Run > Enter: %APPDATA%
      Select Ok.
      In the Explorer Window that appears, open the Ansys folder...
      Rename the v194 folder to v194_old. (assuming you are using 2019R2.)
    • rodmarti
      It works.
      Someone here already suggested me to do this before.
      However, I didn't use Ansys for a while and when I needed to use again, I needed to create a new appdata folder.
      What really worked was to install the R3 version. In this version my models never crashed.
      Thank you!
