August 9, 2019 at 5:38 pm
sdasappa
SubscriberHi,
I am having issues with Fluent 19.2. I have created a simple mesh in Workbench Meshing and once I try to import a known working CHEMKIN mechanism, Fluent crashes. The mechanism complies correctly as the .out files are created with no error.
The console has the attached message which I am unable to debug. "0: mpt_accept: error: accept failed: No such file or directory"
I have tried the same project with the exact same mechanism in Ansys 18 on a different computer which works.
I will appreciate any help.
Thanks
August 12, 2019 at 8:15 am
DrAmine
Ansys EmployeeCheck the *.out files generated on reading the CHEMKIN files. If they are okay, check your setup without CHMEKIN.
August 12, 2019 at 5:09 pm
sdasappa
SubscriberHi Amine,
Firstly, thank you for the reply. I really appreciate it especially as I have gotten no where.
The .out files do not have any error and the mechanism complies fine. I tried to run the simulation without species transport and it works fine. I also tried installing R19.1 and that showed the same issue. I tried turning off all internet connections and again it failed. I am running blind right now but willing to try any suggestions. This is a mechanism I have used on another computer and it worked fine. As I mentioned in the other post, the error log file just says abnormal exit at various nodes. I looked at the Windows application log as well and it did not indicate anything. Only Fluent crashes but Workbench is still open.
Here is a screenshot of the initial settings.
As I said, Any help will be appreciated.
Thanks
Shruthi
August 13, 2019 at 5:06 am
DrAmine
Ansys EmployeeJust iut of curiosity can you run this case on another computer?
Does the case crash right away after initialization or at first iteration. The issue has to Do with the chemistry. -
August 13, 2019 at 5:11 am
sdasappa
SubscriberHi Amine,
I did run it on Ansys 18 in another computer and it worked. I tried on Ansys 19.2 on the other computer and that crashed again. It crashes during initialization.
The chemistry complies fine. The .out file has no error. I suspect it crashes when it's trying to load the output file but I'm unsure why and how to fix it. I am using the USC Mech 2 chemistry.
Could it be some kind of access issue?
Thanks
Shruthi
August 13, 2019 at 12:09 pm
DrAmine
Ansys EmployeeI am not sure. Is it possible to try a newer ANSYS Fluent version like 2019R2?
August 13, 2019 at 12:12 pm
sdasappa
SubscriberIs that different from 19.2? I tried on both available free downloads on Ansys website.
I assumed 2019 R2 was 19.2 hence mentioned it as that -
August 13, 2019 at 12:28 pm
DrAmine
Ansys EmployeeNo 2019R2 is not 19.2. Can you provide a valid university mail address?
2524
2066
1279
1096
457
