October 26, 2018 at 4:06 pm
bolla2
SubscriberHello there!
I'm just here to give some feedback which is really annoying.
I recently upgraded from ANSYS 19.1 to 19.2 and got surprised that Fluent window keeps poping up every time it has a message/warning/etc.
I'm simulating a quiet long transient flow and I need to save as many .cas, dat, other reportable file as possible. As I stated it takes some hours to end the calculation but in the meantime I wanted to do some other work too (e.g. writing reports or just watch some video), but every time Fluent saves files, its window becomes active, pops over everything.
I understand that it's a complex program, it has and will have bugs, but nothing we can handle. But this one makes my computer useless during any simulation.
Please look after this issue.
Regards
October 26, 2018 at 6:39 pm
Karthik R
AdministratorHello,
Are you running Fluent in WorkBench or as a standalone run? If I understand the issue, Fluent window pops open every time it is attempting to save and write .cas and .dat files. Please let me know and I can test this at my end and get back to you with comments.
Also, I am moving this question to the 'Fluid Dynamics' thread. Just FYI.
Thank you.
Best Regards,
Karthik
October 26, 2018 at 6:57 pm
bolla2
SubscriberHello,
I run it in Workbench. Thankfully Fluent not just attempt to save but save them too.
I think not the saving procedure is the problem. It happens every time Fluent opens a new message like the "Calculation complete", etc.
Thank you in advance
Laci
October 26, 2018 at 7:16 pm
Karthik R
AdministratorHi,
Thanks for this information. Please give me some time to get back to you.
Best,
Karthik
October 26, 2018 at 8:45 pm
bolla2
SubscriberHi,
I'm using the Student version.
Tomorrow I try to create a short video about what I'm experiencing, maybe that helps.
Anyway, thanks for the testing so far.
Laci
October 26, 2018 at 9:00 pm
Karthik R
AdministratorHello,
Actually, you are right about this. I misunderstood your question earlier. I thought you were noticing that Fluent was showing pop-ups every time it would save.
Fluent does show up when calculation is completed. It is a way of notifying the user that Fluent has completed the calculation. I tested this on 19.1 and it seems to be doing the same on 19.1 as well.
Are you seeing anything quite different for this?
Thank you.
Best Regards,
Karthik -
October 26, 2018 at 9:50 pm
bolla2
At the end of calculation it would be okay to pops over other windows, but it happens every occasion when it wants to tell me something. (to be clear, I had to rewrite the last 3 word, because Fluent sent a message about saving case file and it poped over the browser)
Check this video, so you can see it more clear:
Hope it helps
Laci
February 11, 2019 at 7:03 pm
liliana_augusto
SubscriberThis is also happening with me. I am running a student version 19.2, standalone mode. At every time step that Fluent is saving .dat file a pop-up window appear, even if the Fluent window is minimized.
That is quite annoying when I am doing something else on the computer, such as reading something. Also, it is easy to click on "cancel" at the pop-up when we are using the computer for another work.
Is there any mode to prevent Fluent to keep showing this pop-up at every saving time-step?
Thanks.
February 11, 2019 at 9:18 pm
DrAmine
Ansys EmployeePerhaps a way to disable focus stealing might help.
February 12, 2019 at 12:39 pm
liliana_augusto
SubscriberI have tried this already, but I did not find any option for disable focus stealing.
February 12, 2019 at 1:37 pm
DrAmine
Ansys EmployeeI can report the same behavior and this is by design. Disable focus stealing might help. The latter might be however OS limited. I will check internally and do some home work.
February 12, 2019 at 1:40 pm
bolla2
SubscriberThank you in advance in the name of everyone
Laci
February 12, 2019 at 1:47 pm
DrAmine
Ansys EmployeeMessages like saving case and data files are not showing to me if I am using the most actual release. Perhaps you all give it a try as soon as it is released as student Version.
March 9, 2020 at 10:20 am
March 9, 2020 at 3:32 pm
Karthik R
AdministratorHello,
Please download the latest release. You should not be seeing pop-ups like the above in the latest version.
Thanks.
Best,
Karthik
November 15, 2020 at 11:00 am
amuim86
SubscriberHave u tried to clear generated data under the solution option?n
