Ansys Free Student Software
Ansys Fluent 2019R2 Hangs at Startup
    • cfd_learner
      I installed Ansys 2019R2. Every module is working except Ansys Fluent which hangs at startup just after:
      MPI Option Selected: ibmmpi
      Selected system interconnect: default
      After that Ansys fluent did not respond for a long time...
      I am using Windows 7 64Bit with Nvidia Quadro  600 Graphics Card.
      Kindly help to solve the issue.
    • tsiriaks
      Could you post the entire screenshot when this hang happens ?
      What if you select the followings in Fluent Launcher
      Parallel
      0 Processes
    • cfd_learner
      I have attached the hanged screen shot along with the crash error. The problem happened in both serial and parallel modes.
      Fluent startup hang.
      Crash window error:
      Crash window error.
    • tsiriaks
      Open CMD Prompt, then issue this command
      "%awp_root194%fluentntbinwin64fluent.exe" -r19.4.0 3d -g -t0
      does this hang ? Or does it show the line that says "Cleanup script file......"
      Also, what is the output of this command (Please post the screenshots of the entire output, or you can just copy paste the text and post it in here)
      "%awp_root194%..Shared FilesLicensingwinx64ansysli_util" -statli 2325@localhost
      Thanks,
      Win
    • cfd_learner
      yes, the cleanup script file shows.
      Could not connect to the lic server. Error connection failed.
    • tsiriaks
      hmm, this is odd.
      What about these two commands
      "%awp_root194%fluentntbinwin64fluent.exe" -r19.4.0 3d -g -t2
      "%awp_root194%..Shared FilesLicensingwinx64ansysli_util" -checkout FLUENT_SOLVER
    • helpme
      I'm facing a similar issue, Fluent doesn't open after set up and gives a message saying FLUENT application failed to start
    • tsiriaks
      Please create a new thread for your issue and provide the info what you have tried and what is the output
    • cfd_learner
      The crash and hang of fluent was caused due to fault in module dx11_2300_x64.hdi. I simply rename this module and fluent start working. This module exists in fluent.exe directory. Now, fluent is using dx9_2300_x64.hdi, as I understand Since this also in the same directory.
      Screenshots:
      Problem/Message:
      CX1940.EXE has stopped working due to fault in module dx11_2300_x64.hdi
      This module located at "C:Program FilesANSYS Incv194fluentntbinwin64"
      Renaming dx11_2300_x64.hdi to dx11_2300_x64_old.hdi resolves the fluent hanging and crash problem. Fluent solver successfully launched and working properly.
      I don't know why this module giving error, likely due to windows update/security requirements, direct X compatibility etc. My OS is Windows 7 X64.
      I did not check the command "%awp_root194%..Shared FilesLicensingwinx64ansysli_util" -statli 2325@localhost
      as I think now it is no use.
    • tsiriaks
      Can you post the screenshots of the resolution you've described, so others can easily follow in the future ?
      Do you get this command working now ?
Viewing 9 reply threads
