March 3, 2022 at 10:36 pm
mimozas1
SubscriberHallo!
I am conducting a 2D airfoil simullation on 90deg AoA. I have the domain divided into 2 bodies as shown next.
March 4, 2022 at 2:50 amKeyur Kanade
Ansys EmployeeIt looks like you have non conformal mesh. You need to define interfaces.
Please check help document for defining interfaces.
Alternatively you can use share topology and create conformal mesh.
Regards Keyur
March 4, 2022 at 4:03 pmmimozas1
SubscriberHallo!
Thanks for the response! In fact i made a manual mesh interface and selected this rectangle as Maching mesh. In fact i am not sure if the right option is matching, cosnidering i want fluid to run through the doimain. I think Mapped, Static, Coupled Wall would be wrong, if i understand the Fluent Users Guide correctly.
If this is not the case and i should change this option please let me know!
Thanks for your help!
MK
March 4, 2022 at 4:51 pmRob
Ansys EmployeeIf you want flow it's definitely not a coupled wall! Check both zones are fluid too.
2524
2064
1279
1096
456
