Ansys Free Student Software
Topics cover installation and configuration of our free student products
Ansys Fluent – At Result, I’m stuck with an “Application failed to connect”
    • Georges Sainte-Rose
      Greetings,
      I have that issue :
      I have tried every methods explained elsewhere, like shutting down all firewalls, make sure all the apps are well installed etc, nothing work.
      Could someone please help ? 🙏
    • Rajeshwari Jadhav
      Hi Georges,
      This is a general error, it is difficult to recover the reason. Can you check if you can open CFD-Post in stand-alone mode? so you can verify if it is a Workbench issue.
      If it does not start, please evaluate to re-install the tool. Note that is now available 2023R2 Version!
      I indeed uninstalled everything and installed a version 2022 R2, it worked well.
      Thank you for your time,
      Have great day !
