Ansys Fluent Energy and Pressure Drop Problem
    • jagar
      Hello everyone. I am trying to do a double tube heat exchanger analysis. According to the actual results, I need to find the pressure drop of 27 pa, the coefficient of friction 0.17, and the nusselt value of 11. but I find all three results completely different. can anyone help?
      inner tube diameter and thickness: 38.2 mm and 1mm
      outer tube diameter and thickness: 82 mm and 6 mm
      lenght of tubes : 1100 mm
      SIMPLE Solver, Realizable K-epsilon models i tried.
      inner tube hot fluid AİR
      ouuter tube cold fluid WATER LİQUİD
      tubes materials are STEEL
    • DrAmine
      Focus on Total pressure drop, first of all.
      Are you taling care sbiut boundary layer resolution?
      Are you having right mass flow/velocity at inlet?
    • jagar
      Yes, I am entering all the limits correctly. because I'm trying to do a numerical analysis of an experimented project. I have all the information about project. I think I entered all of them correctly as inputs. I am sharing an example below that I found on the internet. its going up like that or keep going down. And im sharing the datas about project.
