Ansys Free Student Software
Topics cover installation and configuration of our free student products
Ansys fluent error
    • Ashagoni Nivas
      Hello
      When I use fluent in workbench
      Geometry and Mesh both work fine
      But in the Set step, it does not work properly
      The message in the Set console
                    Welcome to ANSYS Fluent 2022 R2
                    Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.
                    Unauthorized use, distribution or duplication is prohibited.
                    This product is subject to U.S. laws governing export and re-export.
                    For full Legal Notice, see documentation.
      Build Time: May 27 2022 08:52:29 EDT Build Id: 10212
      Connected License Server List:
           This is a student version of ANSYS FLUENT. Usage of this product
           license is limited to the terms and conditions specified in your ANSYS
           license form, additional terms section.
      Host spawning Node 0 on machine "LAPTOP-KN02JFQD" (win64).
      = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
      = RANK 0 PID 29344 RUNNING AT LAPTOP-KN02JFQD
      = EXIT STATUS: -1073741515 (c0000135)
      = RANK 1 PID 18396 RUNNING AT LAPTOP-KN02JFQD
      = RANK 2 PID 11968 RUNNING AT LAPTOP-KN02JFQD
      = RANK 3 PID 4568 RUNNING AT LAPTOP-KN02JFQD
      When I turn back to the workbench
      It says" Fluent Application cannot be verified to connect"
      Why is this happening?
      I need to finish my master's thesis urgently
      Thank you..!
    • George Karnos
      Check your Firewall is not blocking any communications of Fluent.
      Also, Check the virus scanner is not blocking anything.
      Check your PATH environment variable to make sure that the PATH statement begins with c:\Windows\System32....
      To check this, Open a Dos Command Prompt window and type in:
      set PATH
      Then hit Enter.
