ansys fluent how to get accurate lift and drag
    • MING-DE GU
      I have try to watch video in youtube to study how to get lift and drag in use ansys fluent
      follow videos step to make foundmental setup in set up inside reference value and monitors force include lift and drag ,but my reference not depth options,however,I have try to run simulation , but lift and drag are little value,i think that not accurate .I want to how to setup can get accurate value or why not depth option
    • Prashanth
      Correct me if I'm wrong: You ran a 2D simulation to calculate the lift and drag forces. You are not sure why the values are not accurate and suspect the depth option in references values panel.
      Yes, you need to set a valid depth reference value for the 2D model.
    • MING-DE GU
      Excuse me,I have problem in 3D simulation set up option is no depth reference select ,but 2D simulation have,I want to know how to get depth options.
    • Prashanth
      A 3D simulation does not have a depth option as you already set the depth literally in the model geometry.
    • MING-DE GU
      thank you
Viewing 4 reply threads
