January 11, 2023 at 5:33 am
LCC
SubscriberI try to simulate the arc in welding so MHD module is used. The source term in the energy equation needs the current density. I wonder if there is a macro that can obtain the current density or other method that can obtain it directly? Thanks a lot.
January 11, 2023 at 10:24 am
Ansys EmployeeIt's complicated. What are you trying to find out, and which plasma model are you using?
January 13, 2023 at 9:06 am
January 13, 2023 at 5:24 pm
Ansys EmployeeWhat paper/setup are you planning on using MHD for? It's designed more for magnetic fields in metal stirring, plasma isn't going to be easy.
January 15, 2023 at 4:03 pm
LCC
SubscriberI use MHD for metal welding and I am trying to simulate the welding arc.
January 16, 2023 at 3:24 pm
Ansys EmployeeThe MHD module will not calculate the magnetic field induced by the arc current. It is not a complete EM solver. If the arc is DC you will need to consider using Ansys Maxwell. If it's high frequency AC you'll need Ansys HFSS, low frequency will work with Maxwell. This is not a straightforward project and should be approached with caution.
January 18, 2023 at 12:51 am
LCC
SubscriberI get it now. Thank you for the well explained answer.
2616
2098
1323
1108
461
