November 4, 2021 at 4:40 am
dmhabig17
SubscriberNovember 4, 2021 at 12:07 pmRob
Ansys EmployeeCan you post the full text? "sasroy" is an Ansys employee and the error message is misleading.
January 1, 2022 at 10:56 pmtemayer17
SubscriberI have also run into this error, and this forum post appears to be the sole relavent google result. Here is the error I keep getting, seemingly at random.
HDF5-DIAG: Error detected in HDF5 (1.10.5) MPI-process 0:
#000: C:\\Users\\sasroy\\Downloads\\CMake-hdf5-1.10.5\\CMake-hdf5-1.10.5\\hdf5-1.10.5\\src\\H5F.c line 509 in H5Fopen(): unable to open file
major: File accessibilty
minor: Unable to open file
#001: C:\\Users\\sasroy\\Downloads\\CMake-hdf5-1.10.5\\CMake-hdf5-1.10.5\\hdf5-1.10.5\\src\\H5Fint.c line 1652 in H5F_open(): unable to read superblock
minor: Read failed
#002: C:\\Users\\sasroy\\Downloads\\CMake-hdf5-1.10.5\\CMake-hdf5-1.10.5\\hdf5-1.10.5\\src\\H5Fsuper.c line 623 in H5F__super_read(): truncated file: eof = 6434736, sblock->base_addr = 0, stored_eof = 6434840
minor: File has been truncated
That directory "Users\sasroy\Downloads..." is not a directory on my computer.
January 4, 2022 at 4:46 pmRob
Ansys EmployeeWhich version of Fluent are you using? I've seen corrupted data saves cause problems but not in 2020 or 2021 builds.
January 25, 2022 at 8:15 amJanuary 25, 2022 at 10:50 amRob
Ansys EmployeeFluent isn't looking for a file there, it's a poorly set up error message. Looking further down the error is a read error on D:/projects/Henfoss...... Can you check the file is present, and that you have read & write permissions in that folder. or may have more information.
January 25, 2022 at 11:12 amANSYS_MMadore
Ansys EmployeeThis must be a product or project issue if all users are seeing this same error that is looking to some other user's directory. Seems all of these users are seeing the same error, something in the project that directs them to "C:\users\sasroy", but none of them are in any way related to user "sasroy". Is this happening with a common project or model files? This wouldn't be a systems issue, something is up with the product or project.
January 25, 2022 at 12:10 pmgdp
SubscriberHi, and thank you for your quick reply. Yes, the file was indeed present in D:/projects/Hensfoss ... I now managed to open it. I don't know what I did different, to be honest. I tried opening with full FLUENT capabilities and not just with PRE/POST option (as I did first), maybe that did the trick. Some users in this chat point out that the issue can be random.
Will leave new comment if I continue to get these messages.
Regards Gonzalo
January 25, 2022 at 12:13 pmANSYS_MMadore
Ansys EmployeeGlad it is working. Make sure any antivirus or security software you may have are not scanning your project files. You should add exceptions to ensure there are no conflicts that could occur from a scan while trying to use the files.
March 2, 2022 at 2:20 amsatri
SubscriberHi I am also getting a similar error message
I am trying to write a case through tui
file/write-case-data ["q1.cas.h5"]
when i try to do this i get this error.
Writing mesh ...
#000: C:\Users\sasroy\Downloads\CMake-hdf5-1.10.5\CMake-hdf5-1.10.5\hdf5-1.10.5\src\H5F.c line 444 in H5Fcreate(): unable to create file
#001: C:\Users\sasroy\Downloads\CMake-hdf5-1.10.5\CMake-hdf5-1.10.5\hdf5-1.10.5\src\H5Fint.c line 1509 in H5F_open(): unable to open file: time = Tue Mar 1 21:10:35 2022
, name = '["Q1.cas"].cas.h5', tent_flags = 13
#002: C:\Users\sasroy\Downloads\CMake-hdf5-1.10.5\CMake-hdf5-1.10.5\hdf5-1.10.5\src\H5FD.c line 734 in H5FD_open(): open failed
major: Virtual File Layer
minor: Unable to initialize object
#003: C:\Users\sasroy\Downloads\CMake-hdf5-1.10.5\CMake-hdf5-1.10.5\hdf5-1.10.5\src\H5FDsec2.c line 346 in H5FD_sec2_open(): unable to open file: name = '["Q1.cas"].cas.h5', errno = 22, error message = 'Invalid argument', flags = 13, o_flags = 302
March 2, 2022 at 2:22 amsatri
SubscriberPlease let me know how to fix this and write a case and data through TUI and resolve the above error message
March 2, 2022 at 12:32 pmANSYS_MMadore
Ansys Employeeare you using brackets in the path or command or file name? It's not showing a full path for the file and if using brackets that would cause problems.
March 2, 2022 at 2:25 pmsatri
Subscriberdo i need to use brackets? I thought fluent will write the case in the folder path specified in the beginning.
I did use brackets earlier.
I was able to write the case if i do wc q1.cas
i could not find this wc command in your tui manual does this wc command write the case as well as data?
or should i write the data separately?
March 2, 2022 at 3:10 pmANSYS_MMadore
Ansys Employeeperhaps could provide additional input on this one.
Thanks
March 2, 2022 at 3:56 pmRob
Ansys EmployeeBrackets can cause problems, in a TUI string they can mean something so best avoided.
"wc" is short hand for "write-case". The TUI commands mostly have a shortened version, but use with caution as there are a few duplicates.
Viewing 14 reply threads- You must be logged in to reply to this topic.
2590
2080
1315
1108
459
