ANSYS FLUENT RESIDUALS
    • Sanjaay
      Hello
      I am trying a simulation of ice melting within a tube. I am not able to view the x,y,z velocities and continuity in the residual graph. All I see is the blue energy line going up and down
    • Keyur Kanade
      please check monitor option is on in residuals panel.
      Keyur
    • Sanjaay
      Yes the monitor option is on but it's still not showing
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      check latest version 2020R1.
      Change background color to black using file - preferences and check.
      Keyur
    • Sanjaay
      It says that the solution is converged from the beginning of calculation itself. Continuity and x,y,z velocities are zero. What could be the reason?
Viewing 4 reply threads
