ANSYS Fluent Residuals
    • kedy4ect
      Hi, may I know how do I reset all the solution data and residual data in fluent?
      Because I found out that the data generated from fluent differs slightly every time I re-run on the same file.
      So I suspect this difference might be caused by the residual data that has been left by the previous solution file.
      Initially, I thought that by clicking solution initialization would clear all previous solution file, but there is still a difference in the data generated.
      The difference is slightly unacceptable as I am performing a cyclic transient simulation.
      Thank you.
    • DrAmine
      you can do that per TUI. Just search for that using the command searcher in Fluent or in the TUI manual.
