Ansys Fluent Setting Up Natural Convection Boundary Condition
    • nguy3394
      Say I have a acrylic rod that have a volumetric heat source at one end, and all the other surfaces are exposed to still air at room temperature. How do I setup the wall boundary condition correctly for this natural convection? When running the calculation, it is always the case that the rod temperature rise up infinitely without ever reaching a steady state. Thank you.
      The wall boundary condition looks feasible. Have you turned on gravity and a temperature dependent air density?
    • nguy3394
      gravity is on. Do I have to model an air block completely encasing the rod?
      If you want to model the buoyant flow around the rod. Otherwise, a convection boundary on the "wet" faces should be OK if you can find the heat transfer coefficient.
Viewing 3 reply threads
