Ansys Products
Ansys Products
Ansys Fluent Setup Failed
    • Jifweif151
      As I had the geometry ready and proceeded to the setup stage, somehow I got the following error msg: "This is an educational executable, and can only be used with cases containing less than 512000 cells. Please exit this fluent session and start another session to continue."
      It should have picked up the Research licence, can you check it's not already in use? n
    • Jifweif151
      Hi Rob, I am not quite sure how to check if the Research licence is in use or not, but I did attempt to only open the Setup page and it still didn't work.n
    • Jifweif151
      Can someone please help? This is my undergrad thesis project which will be due soon.nThanks!n
    • Jifweif151
      Here is the console: n{n       Welcome to ANSYS Fluent 2020 R1nn       Copyright 1987-2020 ANSYS, Inc. All Rights Reserved.n       Unauthorized use, distribution or duplication is prohibited.n       This product is subject to U.S. laws governing export and re-export.n       For full Legal Notice, see documentation.nnBuild Time: Dec 2 2019 14:15:26 EST Build Id: 10114  n nn   --------------------------------------------------------------n   This is an academic version of ANSYS FLUENT. Usage of this productn   license is limited to the terms and conditions specified in your ANSYSn   license form, additional terms section.n   --------------------------------------------------------------nHost spawning Node 0 on machine xxxxxxxx (win64).nWARNING: No cached password or password provided.n     use '-pass' or '-cache' to provide passwordnHost 0 -- ip 130.179.216.94 -- ranks 0 - 3nn host | 0n======|======n  0 : SHMnn Prot - All Intra-node communication is: SHMnnn-------------------------------------------------------------------------------nID  Hostname     Core O.S.     PID  Vendor            n-------------------------------------------------------------------------------nn3  xxxxxxxx 4/8 Windows-x64 2112  Intel(R) Core(TM) i7-7700HQ nn2  xxxxxxxx 3/8 Windows-x64 11748 Intel(R) Core(TM) i7-7700HQ nn1  xxxxxxxx 2/8 Windows-x64 11248 Intel(R) Core(TM) i7-7700HQ nn0*  xxxxxxxx 1/8 Windows-x64 25584 Intel(R) Core(TM) i7-7700HQ nhost xxxxxxxx   Windows-x64 20532 Intel(R) Core(TM) i7-7700HQ nnMPI Option Selected: ibmmpinSelected system interconnect: defaultn-------------------------------------------------------------------------------nnCleanup script file is C:\Users\xx\Desktop\cleanup-fluent-xxxxxxxx-20532.batnn> Multicore SMT processors detected. Processor affinity set!nReading C:\Users\xx\Desktop\10% WWR Single_files\dp0\FFF\MECH\FFF.1.msh...nBuffering for file scan...nn 175547 nodes, binary.n  73036 nodes, binary.n  56384 triangular wall faces, zone 1, binary.n  56492 triangular wall faces, zone 2, binary.n 1219903 triangular interior faces, zone 3, binary.n 1226073 triangular interior faces, zone 4, binary.n  16582 triangular interface faces, zone 9, binary.n  16606 triangular interface faces, zone 10, binary.n 628193 tetrahedral cells, zone 5, binary.n 631311 tetrahedral cells, zone 6, binary.nnBuilding...n   meshntauto partitioning mesh by Metis (fast),ntdistributing meshnttparts....,nttfaces....,nttnodes....,nttcells....,n    bandwidth reduction using Reverse Cuthill-McKee: 316167/4316 = 73.2546nError at host:  This is an educational executable, and can only be used n with cases containing less than 512000 cells. n Please exit this fluent session and start another session to continue.n}
    • George Karnos
      Can you try the following:nIn the License preferences as in your first post, change all licenses to 0, except for Academic Research CFD.nThis will only use that license.nIf this does not work, can you please run:nStart->All Programs->Ansys 2020 R1->Ansys Client Licensing->Client ANSLIC_ADMIN Utility 2020 R1nWhen this appears, choose:nView Status/Diagnostic Options->Display the License statusnCopy all in the window(scrolling up too) and paste it here.n
    • Jifweif151
      Hi, Array nas for your first suggestion, the console showed Unexpected license problem; exiting.nnWith all the licence disabled except the Academic Research CFD, here is the msg shown when I run the ADMIN utility:nnOct 22, 2020 11:36: Attempting to display the license status...n  n====================================================================================================nDISPLAY THE LICENSE STATUS:nnANSYS Licensing Interconnect path = 2325@ansys-lm.cc.umanitoba.cannANSYS FLEXlm license path = 1055@ansys-lm.cc.umanitoba.cannn***** Note: Due to a FLEXlm limitation, all tasks may not be found *****nn<================================================================================>n<================================================================================>nnn***** LICENSE SERVER STATUS: 1055@ansys-lm.cc.umanitoba.ca *****nnnlmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.nFlexible License Manager status on Thu 10/22/2020 11:36nn[Detecting lmgrd processes...]nLicense server status: 1055@vpl-licmgr01.cc.umanitoba.can  License file(s) on vpl-licmgr01.cc.umanitoba.ca: /usr/local/licences/dat/ansys/license.dat:nnvpl-licmgr01.cc.umanitoba.ca: license server UP (MASTER) v11.16.4nnVendor daemon status (on vpl-licmgr01.cc.umanitoba.ca):nn ansyslmd: UP v11.16.4nFeature usage info:nnUsers of aa_t_a: (Total of 50 licenses issued; Total of 2 licenses in use)nn aa_t_a v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021n floating licensenn  zhoub345 venus.cc.umanitoba.ca venus.cc.umanitoba.ca 16095 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2079), start Sat 10/17 19:25n  Geoff LAPTOP-B27LRB8I LAPTOP-B27LRB8I 14128 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1068), start Thu 10/22 9:26nnUsers of aa_r_cfd: (Total of 25 licenses issued; Total of 25 licenses in use)nn aa_r_cfd v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021n floating licensenn  grayg34 cdr2255 cdr2255.int.cedar.computecanada.ca 150133 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 283), start Tue 10/20 0:20n  grayg34 cc08.cc.umanitoba.ca cc08.cc.umanitoba.ca 44682 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 432), start Thu 10/22 10:39nt1 RESERVATION for GROUP BIBEAU_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt6 RESERVATIONs for GROUP BIROUK_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt3 RESERVATIONs for GROUP CLARKS_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt2 RESERVATIONs for GROUP HOLLAE_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt1 RESERVATION for GROUP BIBEAU_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt3 RESERVATIONs for GROUP ORMIST_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt1 RESERVATION for GROUP MEDEPT_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt3 RESERVATIONs for GROUP ORMIST_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt3 RESERVATIONs for GROUP MEDEPT_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nnUsers of aa_r_dy: (Total of 25 licenses issued; Total of 0 licenses in use)nnUsers of aa_r_me: (Total of 25 licenses issued; Total of 21 licenses in use)nn aa_r_me v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021n floating licensenn  asgaria me-yl-01.eng.umanitoba.ca me-yl-01.eng.umanitoba.ca 19848 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2141), start Mon 10/5 7:04n  babarinv n177 n177 4084 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1561), start Thu 10/15 18:51n  babarinv n168 n168 6969 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1742), start Thu 10/15 18:51n  babarinv n170 n170 21665 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 742), start Thu 10/15 18:51n  babarinv n153 n153 11161 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 150), start Thu 10/15 18:51n  babarinv n153 n153 11092 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 339), start Thu 10/15 18:51n  babarinv n264 n264 14903 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 561), start Thu 10/15 18:51n  babarinv n294 n294 5754 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2739), start Thu 10/15 18:51n  babarinv n204 n204 20647 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1858), start Fri 10/16 2:08n  babarinv n208 n208 21720 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2388), start Fri 10/16 2:08n  babarinv n204 n204 20652 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1424), start Fri 10/16 2:08n  babarinv n208 n208 21807 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2820), start Fri 10/16 2:08n  babarinv telichev2.eng.umanitoba.ca telichev2.eng.umanitoba.ca 9868 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 3707), start Sat 10/17 8:22n  abedineh ME-OJO-R1.eng.umanitoba.ca ME-OJO-R1.eng.umanitoba.ca 10360 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1180), start Tue 10/20 11:38n  luoy luo1.eng.umanitoba.ca luo1.eng.umanitoba.ca 16248 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2412), start Tue 10/20 21:04n  SAFIANA me-xl-r1.eng.umanitoba.ca me-xl-r1.eng.umanitoba.ca 10352 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1987), start Wed 10/21 13:04n  domingop me-itv-domingo.eng.umanitoba.ca me-itv-domingo.eng.umanitoba.ca 9744 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2909), start Wed 10/21 16:25n  domingop me-itv-domingo.eng.umanitoba.ca me-itv-domingo.eng.umanitoba.ca 260 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1377), start Wed 10/21 16:39n  domingop telichev2.eng.umanitoba.ca telichev2.eng.umanitoba.ca 9684 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 3412), start Wed 10/21 17:20n  domingop telichev2.eng.umanitoba.ca telichev2.eng.umanitoba.ca 11844 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 3631), start Wed 10/21 17:34n  babarinv me-itv-victor2.eng.umanitoba.ca me-itv-victor2.eng.umanitoba.ca 7660 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2641), start Thu 10/22 11:34nnUsers of aa_r_hpc: (Total of 128 licenses issued; Total of 128 licenses in use)nn aa_r_hpc v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021n floating licensenn  grayg34 cdr2255 cdr2255.int.cedar.computecanada.ca 150133 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1658), start Tue 10/20 0:20, 32 licensesnt20 RESERVATIONs for GROUP BIROUK_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt4 RESERVATIONs for GROUP CLARKS_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt4 RESERVATIONs for GROUP HOLLAE_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt32 RESERVATIONs for GROUP TELICH_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nt36 RESERVATIONs for GROUP ORMIST_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nnUsers of aa_mcad: (Total of 125 licenses issued; Total of 0 licenses in use)nnUsers of aim_mp1: (Total of 100 licenses issued; Total of 0 licenses in use)nnUsers of acfd_vki: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of afsp_gui: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of afsp_optigrid: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of afsp_viewmerical: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of ensight_enterprise: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of envision_pro: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of am_prep: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of granta_sim_mat_data: (Total of 75 licenses issued; Total of 0 licenses in use)nnUsers of aa_ds: (Total of 50 licenses issued; Total of 0 licenses in use)nn  nn====================================================================================================nn
    • George Karnos
      Thank You for the License Status.nIt does look like all of the Research CFD licenses are in use/Reserved for others:nUsers of aa_r_cfd: (Total of 25 licenses issued; Total of 25 licenses in use)nn aa_r_cfd v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021n floating licensenn  grayg34 cdr2255 cdr2255.int.cedar.computecanada.ca 150133 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 283), start Tue 10/20 0:20n  grayg34 cc08.cc.umanitoba.ca cc08.cc.umanitoba.ca 44682 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 432), start Thu 10/22 10:39n1 RESERVATION for GROUP BIBEAU_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n6 RESERVATIONs for GROUP BIROUK_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n3 RESERVATIONs for GROUP CLARKS_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n2 RESERVATIONs for GROUP HOLLAE_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n1 RESERVATION for GROUP BIBEAU_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n3 RESERVATIONs for GROUP ORMIST_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n1 RESERVATION for GROUP MEDEPT_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n3 RESERVATIONs for GROUP ORMIST_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)n3 RESERVATIONs for GROUP MEDEPT_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)nnnThere are 23 reserved and the user  grayg34 is using 2.nYou can talk with your License Server administrator to see if they can add you to a reserve list or contact the user grayg34 to see if they can release 1 license.nThis will allow you to use the Research CFD license.n
    • Jifweif151
      Thanks a lot for your help! n
Viewing 8 reply threads
