October 28, 2018 at 2:44 pm
Shahbazsyed
SubscriberHey guys,
I am checking for bad faces and I found some areas. It apparently has something to do with corrupt rendering. How do I fix this on my Geometry? what am I supposed to do?
Thank You.
October 28, 2018 at 3:21 pm
FrankD
Ansys Employee -
October 29, 2018 at 6:40 am
Keyur Kanade
Ansys EmployeeHi,
You can delete faces and recreate them using different options in SpaceClaim.
Can you pleas insert some images here. As ANSYS employee, we can not download attachments.
Keyur
October 31, 2018 at 9:17 am
seeta gunti
Ansys EmployeeAdding to above, we have some tips and tricks on cleaning of geometry in the given link. Please go through the link and it may help you out.
Seeta
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2688
2134
1349
1136
462
