ANSYS Fluent stops writing to output files after few iterations
    • kaluvateja
      Hi
      I was trying to write the output to files along with transcript files in ANSYS Fluent. It stopped writing to them after a few iterations. I tried reinstalling the software but still, the problem exists. I am using ANSYS 2019 R3 on Dell Xeon(R) 6240 workstation.
      Thanks
      Does something happen in the software? Once a transcript etc is started it ought to continue until told to stop.
    • kaluvateja
      I don't see any changes, but the simulation was still going on without any problem. I checked if there are any installation errors but there aren't.
      If it's still running then there's something wrong with the disc (is it full) or the set-up.
    • kaluvateja
      I did check them too.
      The disc has a lot of space left
      I simulated the same case on a different workstation, it worked fine there.
      Possibly hardware related then, or set-up.
    • kaluvateja
      I couldn't figure out what the error exactly is, I appreciate any input attempting to solve this issue.
      Thanks
      Is it repeatable? Ie does it stop at the same point every time on that machine?
    • kaluvateja
      No, it stops differently everytime.
    • bkovarovic
      I am having the same issue with the report file, animations and macros.  It is completely random and I have tried it with 2 different machines.  Any advice?
Viewing 9 reply threads
