July 27, 2018 at 12:30 am
oobiols
SubscriberHello everybody and thanks for reading.
I installed ANSYS 19 in my 32-core machine. I want to use Fluent to solve Fluid Dynamics cases. I want to use multi-block grids, and I am having no issues when solving my own benchmark cases (Compressible flow around a 2D Cylinder (1block), Compressible flow around a 2D Cylinder (2 blocks), Compressible flow around an airfoil (8 blocks) ) as test cases. These cases work fine.
However, I eventually want to solve a larger case. This larger case contains a grid with 248 blocks, and the entire case file's size is 17GB. When I try to read the case, I get the following messages in the console:
"Multicore SMT processors detected. Processor affinity set!
"Reading case ..."
"buffering for file scan..."
"MPI Application rank 0 killed before MPI_Finalize() with signal 9. /fluent installation directory/ : line 3191: 31467 Killed. $EXE_CMD $CX_FLAGS $FL_FLAGS "$HOST_FUNCTION. The fluent process could not be started"
There is no other message in the console. Before sending this discussion I tried hard to figure the issue out with suggestions from other posts, but none could help me figure it out. All I could conclude - and probably I am wrong - is that it may be either a RAM memory issue or a permission on the number of compute nodes I am allowed to use due to my license.
Help is much appreciated. Thank you very much
Some specifications of my machine are:
Total RAM: 62GB
Available RAM: 60GB,
Available buff/cache: 60 GB
CPU model name: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
July 27, 2018 at 9:47 am
Ansys EmployeeOn the student bundle you're capped at 512k cells, and possibly 4 cores. Exceeding these should give a licence error. Running out of RAM can give that error, or a malloc error, and a 17GB case file is huge. If you try reading it into Fluent in standalone mode what happens? I also suggest monitoring RAM usage via Task Manager (Windows) or "top" (LINUX) to see if that's the cause.
July 27, 2018 at 10:24 pm
oobiols
SubscriberThanks! Yes, it was a RAM memory problem. I could try a larger RAM memory and it could handle the case. I really appreciate your help. Monitoring RAM usage also helped. Thanks!!
2524
2066
1279
1096
457
