Ansys Products
Ansys Products
Ansys Fluent watertight workflow generating meshing “Error: Poly meshing no”
    • mehdi Abbas
      I am getting this error while I try to mesh a concentric cylinderical object with thin walls. The thickness of the outter wall is 0.14mm. XCan anyone suggest as to what the solution could be for this
      Error: Poly meshing not completed.
      Error Object: #f
      Error Object: #f
    • Nikhil Narale
      Hello, what is the minimum size of the surface mesh?
      Can you also share the screen grabs of the CAD, surface mesh, and the error?
      Are you also adding BL?
