December 6, 2017 at 4:32 pm
sdeb31
SubscriberI am trying to solve the generic transport equation
for diffusion only. I made a UDF for the diffusion. This is a four-sided geometry.
#include "udf.h"
#include "mem.h"
DEFINE_DIFFUSIVITY(magfun, c, t, i)
real diff;
diff = -1/(NV_MAG(C_UDSI_G(c,t,0))+0.000000001);
return diff;
which I used in material properties of the fluid. I also have a source term which I used in cell zone conditions. When I run the simulation, not only do I get different answer each time I run the simulation, none of the results match what I should be getting.
When I save and close the file, and reopen it, I get this error
Can anyone help me out?
December 7, 2017 at 8:25 am
Luca
SubscriberI am new in this field, but a reasonable question could be: How much nodes has your mesh? Different results from the same simulation could come from a dipendence with the mesh. Try to refine your mesh and restart your job. (I had the same problem, without the error, and i solved it only refining the mesh).
I hope this could help you!
Luca
December 7, 2017 at 9:54 am
Raef.Kobeissi
SubscriberHello I agree with Luca, any simple change in your setup, mesh, or even model will give you a different result.
4998
3129
2359
1306
922
