ANSYS Heatflow Negative Value Meaning
    • jt2016
      Hello.
      I am doing this problem but I do not understand what ANSYS 15.0 is telling me.
      Please see below for the full explanation.
      Thank you for your time and help.
      Generally negative fluxes on a boundary mean material/energy is leaving the system. If you plot temperature how does it compare to the set temperature on that boundary?
    • jt2016
      Thank you for the response Mr. Rwoolhou.
      I listed the temperature on path 1 and one of the nodes had a temperature of 67.953 F (which is a little less than 68 F from the convection boundary). Would this mean that the heat flux is going into the concrete?
      If the temperature on the outside is lower than on the inside heat will leave the domain.  I don't know enough about Mechanical results to know if a single node would cause that: in CFD I'd look at area average temperature.
    • jt2016
      Thats okay. No worries. Thank you for the feedback.
Viewing 4 reply threads
