ANSYS HFSS 3DLayout 22R2 EDBErrorException: Definition in use.
    • Nithin Kumar Santha Kumar
      I'm running a script to set up a module in 3DLayout. I get the following error and the script execution fails:
      *Global - Messages
        [info] OpenGL Version: 4.6.0 - Build 31.0.101.1999
        [warning] C:\Program Files\AnsysEM\v222\Win64
        [warning] processPCB.py started
        [warning] top_level_directory = C:\Users\nkumar\Desktop\XXXXX\YYYYY\ExampleFolder
        [warning] made directories
        [warning] copied input files to directory_1_input_files
        [warning] Imported .aedb at 2023-05-18 11:04:20
        [error] EDBErrorException: Definition in use. [D:\AnsysDev\nextgen\lib\EDBKern\source\ComponentDef.cpp 609]  In file "C:/Users/nkumar/Desktop/XXXXX/YYYYY/setupScript.py", line 450 ---- While executing script: C:/Users/nkumar/Desktop/XXXXX/YYYYY/setupScript.py
        [error] Error executing script in C:\Users\nkumar\Desktop\XXXXX\YYYYY\setupScript.py:
      The line (line 450) the error is pointing to in the script is:
      236 >>> clr.AddReference('Ansys.Ansoft.Edb)
      237 >>> import Ansys.Ansoft.Edb as edb
      450 >>> db = edb.Database.Open(aedb_folder_3_updated_stackup, False)
      If I run the script again, the script works. I'm trying to figure out why this is happening. Any help would be greatly appreciated.
      Thanks,
      Nithin
    • Aymen
      Please have a look at the PyAEDT examples, especially the example concering EDB creation:
      https://aedt.docs.pyansys.com/version/stable/examples/index.html
      This should give an idea about how to properly create an EDB using automation. If you think there is an issue with PyAEDT, please file it here:
      https://github.com/ansys/pyaedt/issues
        Hi Aymen,
        This script was written in IronPython and doesn't use PyAEDT.
        Thanks,
        Nithin
