August 13, 2019 at 6:52 pm
kjohnson10
SubscriberGood Afternoon,
I designed a four-armed helical antenna for roughly 70GHz, successfully.
However, when I try to increase the size of the antenna, and optimize it for a lower frequency, I get the following error message:
Below is data for results of each simulation (first, 70GHz, and then the lower frequency results):
****************** 70GHz
PROFILE DATA:
Convergenece:
Matrix Data:
Mesh Statistics:
*************** Lower Frequency
Profile Data:
Convergence:
Matrix Data:
Mesh Statistics:
Does anyone know what can be done to make this fly?
Respectfully,
Kerry Johnson
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
