May 16, 2022 at 3:16 am
ntdat
SubscriberHow can I enable multicores for drawing planar helix coil? Currently, HFSS only uses 1 core for drawing planar helix coil, so it takes a long time to render the 3D model.
I'm using Ansys21.
Thank you
May 30, 2022 at 5:01 pmPraneeth
Please provide more information about your issue to help us serve you better.
The HPC setting can be utilized for specifying the cores and RAM utilization.
Kindly share snapshots of design that you are trying to draw. Generally model rendering does not take long time.
All the very best.
Praneeth.
- Maxwell, HFSS or Q3D?
- Error
3744
2570
1785
1236
594
