Ansys Free Student Software
ANSYS HPC license limitation?
    • yugiohmumi
      Dear ANSYS team,nnI got some problems when running ANSYS on our supercomputer systems. The command to run looks like:nfluent -r20.1.0 3ddp -pshmem -host -t 120 ... ...nnHowever, I got the following errorsnUnable to spawn node: license not available.nANSYS MANAGER ERROR: Not enough Fluent - HPC licenses 120/100.nnI was told that our license has no limit to the size of our ANSYS runs. But there are some online discussion saying that 16 HPC cores are available per license.n I was totally confused!nnCould you please clarify n1) What are the 120 and 100 in the error messages?n2) What are the license limitation or how I can check my license limitation?n2) Is there anyway to resolve it?.Thanks a lot,nn
    • Hunter Wang
      run below command, send the outptu messaages, please. n{installed_path}/ansys_inc/shared_files/licensing/linx64/ansysli_util -printavailn
    • ANSYS_MMadore
      120 is the number of cores it is being asked to run on, and 100 appears to be the number of HPC tasks that are available. Can you try running with fewer than 100 cores?n
    • yugiohmumi
      Thank you huwang and mmadore for the quick response.n1) I do not have (root?) access to our license server but will get the ansysli_util -printavail information when possible.n2) 100 appears to be the number of HPC tasks. This is probably the point.The user probably only allocated 100 CPUs in his/her job. Let me see if I can find the information.n(so it is not a limit from the license, or there is no 16 HPC cores per license limitatio.)
    • ANSYS_MMadore
      ArrayThe user selected 120 cores for their job, that's the -t 120. They need to request fewer tasks as it appears there are only 100 HPC licenses on the server.nnThe 16 HPC cores per license isn't a limitation but something that is provided with each license, but they are not cumulative. Each license has access to those 16, but not the 16 from other licenses. So they have access to the 16 and any additional purchased HPC licenses in the license file.n
Viewing 4 reply threads
