September 16, 2017 at 5:36 am
SANJU
SubscriberI want to simulated IC Engine.
So where do i get required files like valve prof. and geometry?
[Edited to removed caps lock!]
September 19, 2017 at 8:42 am
Vishal Ganore
Ansys EmployeeYou could get started with this simple tutorial on IC engine:
September 21, 2017 at 1:20 pm
SANJU
SubscriberTHANKS A LOT FOR YOUR REPLY
BUT I WANT INPUT FILES FOR GIVEN VIDEO ON IC FORTE ANALYSIS ANSYS
September 25, 2017 at 9:44 am
Vishal Ganore
Ansys EmployeeI am not sure whether such geometry files are publicly available for download. But we have several IC engine simulation tutorials using Forte available for our paid customers having access to ANSYS customer portal.
May 17, 2018 at 3:05 pm
sanjaysajeevan008
SubscriberHAI SANJU....DID YOU GOT ANY FILES REQUIRED RUN IC ENGINE? CAN YOU SHARE IT WITH ME IF POSSIBLE PLEASE? I AM NEW TO THAT.. PLEASE HELP ME PLEASE.
May 23, 2018 at 11:26 am
Vishal Ganore
Ansys EmployeeMost of our geometry files are available under ANSYS customer portal. You need a paid version of ANSYS products to be able to access those files.
May 28, 2020 at 5:17 am
zudeng24
SubscriberI can't get access for this video,
I get the available one? -
March 23, 2021 at 8:31 am
Prasad_Bhandkar
SubscriberWhere do I get tut_port.x_t file For IC Engine tutorial??n
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
