August 12, 2018 at 11:34 pm
Bishoy Magdy1
SubscriberPlease can i get the temperature distribution inside the engine over the walls of the cylinder using ic engine module?? -
August 13, 2018 at 10:33 am
Ansys EmployeeIf you're using the IC tools to set up the CFD model then yes, as it's one of the normal fields that is solved. Please can you elaborate on the question, and what you're trying to do?
August 13, 2018 at 10:39 am
Bishoy Magdy1
SubscriberI want to know the temperature distribution on the walls of a cylinder of an engine -
August 13, 2018 at 10:40 am
Bishoy Magdy1
SubscriberI really appreciate your kindness
2688
2138
1355
1136
462
