March 12, 2021 at 8:31 pm
Shin-Sung Kim
Ansys EmployeeIn this post, we will study Brewster’s law that predicts the reflected light of an unpolarized light is polarized (to be more precise is s-polarized). This angle is defined by the Fresnel equation:
ϴ=arctan(n2/n1)
where n1and n2 are the refractive indices of the initial and the second media, respectively. From the theory, we expect a zero reflection for the p-polarized light at ϴ~56 degrees.
We can use the stackrt to obtain the reflection in terms of the incident angle.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2630
2110
1335
1110
461
