March 7, 2021 at 1:10 am
Kyle
Ansys EmployeeNote: This post was copied over from the Lumerical Knowledge Exchange
In order to interpret the results from power monitors correctly it is important to understand (1) the normalization used and (2) the effect of the source amplitude.
There are two normalization states: “CW normalization” and “No normalization”. You can select this in the “Setting” menu as shown below:
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2600
2088
1319
1108
459
