March 8, 2021 at 9:18 pm
Guilin Sun
Ansys Employee???????????,???????????,????????????????????????????????????????????????,????????(????)???????n ????????,??????????,???????????????,?????????????,????????????????????,??????,??????????????n1. ??RAMn ????????????,??????,???????????????????,???????????n ???????,????????6-12 GB,??????? 48-96 GB ????n ???????????????,??????,?????????????????????????????n2. ???? Memory bus speedn ??CPU?????????????????,??????????n3. ????? Memory bandwidthn ??????????????????n4. ????? Memory Channelsn ???????????????????????????????????????4????????4?????????n5. CPU???n ??????,Lumerical?FDTD Solutions???????CPU??????????????????????,??????????????????,?????????????????CPU?????????????????Scaling(????),????????????????????????????CPU??????n ???CPU????????(??????,???hyper-threading),??????????????CPU???????????????????????,????????CPU?????????????n Intel ? AMD ?CPU??????n6. CPU???clock speedn ????CPU???????????????,??????FDTD Solutions?????,????,??????????,??????????????????????? (memory bandwidth)?????????????n7. ?CPU????n ?CPU??????????????,????CPU??????????????????????CPU???????????????????CPU????????????,???????,???????CPU?n8. ????n ????GPU???????????????,??????????????????;GPU?????????????,????????????,??????,???????,???????CPU????????n**9. ????:**??????????,??????????,????????????????????,???????????????,????????? ??,?????Cluster??,?????????????????? InfiniBand??,???????????n**10. ?:**Lumerical???????(2006~2009)n FDTD Solutions 500%+ Faster via Intel?s Nehalem Microarchitecture n Parallel Processing and FDTD Solutions n 64-bit Computing and Photonic Design Software n New Multi-Core Processors Boost FDTD Parallel Performance n??????????? :n??FDTD?????????n
Viewing 0 reply threads
Trending discussions
- 询问关于FDTD和matlab软件的互联问题 ——appopen
- Ansys Insight: FDTD 和 varFDTD 常见的发散原因以及处理
- 如何仿真一维光子晶体能带?
- 老师,您好。FDTD中simulation bandidth和source中wavelength区别在哪里,仿真根据哪个进行?
- Ansys Insight: FDTD 如何设置圆偏振光
- 左旋圆偏振光透过超表面后,获得的右旋圆偏振光能量比入射的左旋圆偏振光能量还要大?
- Ansys Insight: script中的数据类型和数据格式 Dataset
- Ansys Insight: 透射率反射率大于1,或者透射率反射率之和大于1的原因与解决方案–综合贴
- Ansys Insight: FDTD算法中pml的类型和选择
- 有效折射率
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
