March 15, 2021 at 11:19 am
Greg Baethge
Ansys EmployeeThis topic describes how to get refractive index or permittivity data from a Sampled Data 3D material from the Materials Group or from a material fit in DGTD or FEEM. It is possible to get both the raw experimental data, and the automatically generated material fit that will be used in the simulation.
See also
Creating sampled data materials
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1285
1096
459
