April 24, 2021 at 1:40 am
Kyle
Ansys EmployeeBy default, the background material in FDTD and MODE simulations is vacuum, with a constant refractive index of 1. This is the refractive index used in the simulation for regions where there is no geometry object.nIn the FDTD, FDE, varFDTD and EME solvers, this can be changed with the background material setting of the solver objects. This setting is found under the General tab of the solver object's edit dialog. For example, in FDTD:nAny material from the Material Database that can be used for a 3D object can be chosen for the background material. If the
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
613
562
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
