March 10, 2021 at 12:18 pm
Greg Baethge
Ansys EmployeeIn FDTD simulations, each field components is calculated at different spatial location within the mesh cell. This can lead to confusion about where it is valid to put monitors, when they are close to other objects. For example, can a time monitor be right at the edge of the simulation region, or does it need to be a few mesh points away from the boundary?
This topic describes how close monitors can be to other objects.
Solvers: FDTD, varFDTD
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1279
1096
457
