March 16, 2021 at 4:01 pm
Taylor Robertson
Ansys EmployeeIt is possible to use parameters while creating your design in Lumerical’s component solvers (FDTD Solutions, MODE Solutions, and DEVICE). There are multiple levels on which you can do this.
model: This is the top-most level in the Objects Tree. All other objects in the model tree can be accessed from here. It is possible to create your structure using the “Setup” script. You can also define variables under the “Setup” tab and use them to parametrize your structure. The following screenshot shows how you can vary the radius and height of a cylinder in your design by using the “Setup” tab in model.
Viewing 0 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
613
562
220
188
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
