Photonics
Photonics
Ansys Insight: How to add new material into material library (FDTD and MODE)
    • Yi-Hao Chen
      While Lumerical optical solvers come with a default library that includes large amount of materials, it is possible that you might want to add a new material that you want to use in your simulation. There are several ways how to do this:nObtain material data from third party source or measure them if you have the equipment and import them from file: https://support.lumerical.com/hc/en-us/articles/360034915093nUse analytic function do describe your material properties: https://support.lumerical.com/hc/en-us/articles/360034394674nUse the basic permittivity or refractive index material models that are supported by material database. You can modify the model parameters in the property panel. See the following KB page for full list of supported basic models: https://support.lumerical.com/hc/en-us/articles/360034394634nUse one of the advanced material models that come with FDTD and MODE (requires you to obtain appropriate coefficients): https://support.lumerical.com/hc/en-us/articles/360034394734nIf you do not have the material data or the related analytical formula on hand, it is good idea to try a quick Google search e.g. "In2O3 refractive index". There is a good chance that you will find the data for the material of your interest.nAlso publications using similar materials or focusing on similar applications tend to be a good resource.nOnce you import your material into Lumerical, it will be saved in the simulation file, but it will not be available in the default material library that is loaded when you start a new project. To modify the default materials that appear when you create a new simulation:nLocate the defaults sub-directory of the installation. By default it will be located at:nWindows: C:\Program Files\Lumerical\defaultsnLinux: /opt/lumerical/api/defaultsnMac: /Applications/Lumerical/.app /Contents/Applications/FDTD\ Solutions.app/Contents/Resources/defaultsnwhere version will be v209, v211, ... etc.nCopy the default simulation file to your desktop. Optionally, you may also want to make a backup of this file.nOpen the file on your desktop and make all required modifications to the material database in this file. This might include deleting unused materials and creating new materials.nCopy this file back into the defaults sub-directory. This generally requires Administrator access.nNext time you start the product, the updated material database should appear automatically.n
Viewing 0 reply threads
