February 10, 2021 at 12:13 am
Guanhui Wang
Ansys EmployeeThere are two ways of doing so. The first method is to define the figure-of-merit in the “Advanced” tab under the “Figure of merit script” window. Please make sure you check the “Use figure of merit script” box when using this method.
Viewing 0 reply threads- You must be logged in to reply to this topic.
Trending discussions- Why am I getting “process exited without calling finalize”, and how do I fix it?
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5264
3299
2469
