March 12, 2021 at 8:02 pm
Shin-Sung Kim
Ansys EmployeeIf you have a large number of simulations that contain certain results, you might want to use a script to open each simulation file and save the results into a file of one of the supported formats (See the File formats tab).
The example script below shows how to extract broadband transmission results from multiple files and save them into a *.txt file that is very versatile and can be imported by many 3rd party tools.
Note that the data is first saved into a matrix, that is easier to manipulate. After the data is collected from all simulation files, the matrix is saved into a *.txt file where each column represents Transmission results from one simulation file. The very first column then represents the frequency/x axis data and it assumes that the dimension of all datasets is identical.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2656
2120
1347
1118
461
