March 12, 2021 at 3:00 pm
Shin-Sung Kim
Ansys EmployeeThis post describes how to get material data from the Material database or from a material fit.
The following plots show the raw sampled data (green dots) of the complex refractive indices of Silicon as well as their fitted curves (blue lines) that are actually used in the FDTD simulation.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2564
2080
1299
1106
459
